396 Cam Choice, Please Help
Old 01-29-2007, 04:34 PM
billc5's Avatar
Default 396 Cam Choice, Please Help
Which one of these would be most suitable
I would like this engine to have near stock idle 600 rpm
Street manors are the goal.
C5
396ci LS6 stock heads
A4, 2400 stall converter, 273 rear end, Mag 112 Blower,
4.125 stroke
6.125 rods
3.905 bore
10.5:1 CR
Headers and 3in center section.
Hi Flow Cats are installed.
These are in stock which is also important.
212/218 - .558/.563 w 1.7 rocker - 115 LSA - ComCam 424
224/230 - .581/.588 w 1.7 rocker - 114 LSA - CompCam 444
207/220 571/.578 w 1.7 rocker 118.5 CL - GT2-3
or
204/218 .555/.551 w 1.7 rocker 117.5 CL Keep the LS6 cam and save $400.
Old 01-29-2007, 06:12 PM
JPH
JPH's Avatar
C5
4.125 stroke
6.125 rods
3.905 bore
10.5:1 CR
or
gt2-3 if i had to pick.
Old 01-29-2007, 06:22 PM
Beast96Z's Avatar
I'd go with the 224/230, but the driveability won't be "like stock". You'll know there is a cam in it. Second choice would be the GT2-3.
Old 01-30-2007, 10:48 AM
billc5's Avatar
well then GT2-3 is the cam I will go with, I dont want to have any idle issues and the lower the idle the better for the A4
Old 01-30-2007, 11:18 AM
LS1Formulation's Avatar
All of those cams are too small for a 396 cube engine. You need something like a 226/230 with XE-R lobes on a 115 LSA. Widening your LSA is what will give you stock like idle characteristics. You have to feed 50 more cubic inches than stock, so even though the cam has added duration, it's not going to idle or behave like it would in a stock 346 cube engine.
Old 01-30-2007, 09:55 PM
Beast96Z's Avatar
Actually decreasing valve overlap is what controls idle charecteristics, but widening LSA is a way to acieve that. Lowering duration is another way. The GT2-3 cam has -23.5* of overlap at .050" wearas the cam you listed has -2* at .050". There will be a pretty big diffrence in idle charecteristics between the 2. Everything about his combo screams low to midrange power, so the cam in question should do a good job with the blower. While he could make more power with a bigger cam, I don't think he is worried about "all out" performance.
Old 01-31-2007, 03:06 PM
Steel Chicken's Avatar
im running a 224/236/116 in mine, and with tuning it has very stock drivability.
And thats on a stock 346. 396 will be even more mild. the gt2-3 is stock without tuning.
Old 01-31-2007, 06:33 PM
billc5's Avatar
Correct, thanks for explaining that, you have confirmed what I'm hoping to achieve with the parts I already have. I just want a well mannered fire breathing, viper beating, C5 grocery getter.
Old 01-31-2007, 10:16 PM
Tom@SpeedInc's Avatar
222/228 ICL, blower cam Jim specd for a customer, worked well, so we used it again, never let us down.
