Exhaust Bolts / Gaskets?
Old 01-30-2007, 07:53 PM
boostedrs's Avatar
Default Exhaust Bolts / Gaskets?
I was trying to find some stock manifold bolts where can I find these? I have one that is broken that I have taken out causing me a killer exhaust leak. Also what gasket should I get to replace this? I have pacesetter long tube headers. Thanks
Old 01-30-2007, 08:02 PM
Tainted's Avatar
the dealer has them. id jsut get some stock gm gaskets thats what i used on my install but I also used grade 8 locker bolts so none would break off
Old 01-30-2007, 08:08 PM
2001NBMZ28's Avatar
Dealer - if it's just one bolt try installing it first and see if the leak goes away.
Old 01-30-2007, 09:38 PM
That's what she said...
TheBlurLS1's Avatar
Check out the manifold bolts for an 06 Trailblazer SS. They have a wider head/flange on them and seem like they'd work better.
Old 01-31-2007, 12:00 PM
jdiddyws6's Avatar
Had a similar problem on mine. Guy that put the headers in broke a bolt off in the head, retapped it at an angle, and I ended up bringing it somewhere to have it retapped and a stud put in. Used percy's gaskets and didn't blow until right before I got it fixed
