Stupid DRL bulbs..
Old 01-31-2007, 12:06 PM
DrewSG's Avatar
Default Stupid DRL bulbs..
OK. So my passenger side DRL bulb is not on during day. It doesn't flash when I hit the turn signal or anything. But when I turn the headlights on, it comes on, but it still does not flash. Even when I turn on the hazard lights on, they don't flash.
Anyone know what the deal is?
Old 01-31-2007, 03:03 PM
smokeum99ta's Avatar
More than likely it needs replaced. There two elements in there and one is burned out.
Old 01-31-2007, 03:06 PM
'99 SLP#24's Avatar
Bulb needs replaced you may be seeing the 194 bleed over from the side when lights are on. Go get ya some 3157 bulbs and let the fun begin!!
Old 01-31-2007, 06:39 PM
Dimitri-'s Avatar
have fun replacing them
(do a search before too, there are about a million threads about drls)
Old 01-31-2007, 06:44 PM
chaman's Avatar
Yeah its a burned bulb. I change them through the brake ducts holes. They burn out so frequently I can change it in less than a minute...
Old 02-14-2007, 09:59 AM
trans-am nut's Avatar
Can someone make this issue a sticky? This same question is all over this tread.
