Po 155
Old 02-02-2007, 10:31 AM
Brian2006's Avatar
Default Po 155
I believe this is one of the rear 02 sensors that is throwing this code. This is correct right?
My question is, my car throws this code and 135 (same code I believe) once or twice a year; is it worth it to buy the corvette bosch sensors or put up with the SES light for a few days till it eventually turns off?
I've also been told that with LTs (which I have) the 02s will throw this code occassionally with cold weather or abrupt weather changes from hot to an all of a sudden cold. This kinda seems to be when it throws the code. Is this true?
Old 02-02-2007, 05:23 PM
Brian2006's Avatar
bumpity
Old 02-02-2007, 05:32 PM
That's what she said...
TheBlurLS1's Avatar
Here's a list of all of them...
https://ls1tech.com/forums/generation-iii-external-engine/509539-water-got-up-intake-what-now-all-diagnostic-trouble-codes-dtcs-inside.html
DTC P0135 HO2S Heater Performance Bank 1 Sensor 1
DTC P0155 HO2S Heater Performance Bank 2 Sensor 1
This is indeed for the front O2 sensors, LT related. The Bosch O2's would help, and probably prevent it, but I'd just live with it unless you're dieing to drop $110.
Here's a link to them for cheap if you ever decide to swap.
http://rep.speedycarparts.com/parts/...gory=C&dp=true
Old 02-02-2007, 09:32 PM
Brian2006's Avatar
Thanks for the info blur that helps. I appreciate it
