Heater blowing very lightly . . . . help
i remember reading on here a while back that there is a easy way to clean out around the blower to removing leaves and debris. . .
heat blows hot, just not very hard.
any help appreciated.
2002 z28
2002 z28
If you have all the fan speeds might not be leaves, but you never know. It's on the passenger side, remove the lower panel?, disconnect the electrical connector to the motor, remove 3 small bolts and the blower motor/cage comes right out.
Closed ex-Sponsor Account
If there is something in your cage you would be able to hear it. I am wondering if you have a blower speed problem.
The selector switch adds resistance to the motor allowing different speeds, when this switch fails (burns up internally) the motor can get stuck on one speed....hope this helps.
