need help installin meth kit.
i cant seen to find a spot under the hood for the meth/water reservoir.so probably goin to tap in to the windshield washer reservoir since its not goin to be used.but im tryin to find the easiest way to get to the windshield reservoir to tap into it. im guessin to start with the front bumper or is there an easier way?any input will help.
LS1Tech Sponsor
Is it the Snow reservoir? If so i also have a TA and it... Check my thread here to see where i mounted it.... Just used some brackets and its in there solid as a rock. Hope this helps!
https://ls1tech.com/forums/showthrea...&page=11&pp=20
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Glad you've solved your problem. For anyone else that is adding a methanol reservoir, you can also do the battery relocate to the trunk thing and stick your alcohol tank in that spot.
