Is NBM available in a spray can anywhere?
Old 02-06-2007, 06:22 PM
LS1Formulation's Avatar
LS1Tech 10 Year
Default Is NBM available in a spray can anywhere?
I'd like to do a little detail painting on my car and I'd like to get it in NBM, but as far as I know, I can't get it in an aftermarket spray can. So if anyone knows otherwise, let me know!
Old 02-06-2007, 07:00 PM
Flamin' bird's Avatar
Duplicolor had a close match when i was painting stuff a few years ago but check out this company:
http://www.expresspaint.com/
I'm getting a can of the same orange I have on the front of my car.
Old 02-07-2007, 04:42 AM
6LITEREATER's Avatar
I'm pretty sure you can get it from the dealer... I did awhile ago.
Old 02-07-2007, 07:17 AM
xlr857's Avatar
I went to an automotive paint supply store and had them mix an exact match for my NBM and put it in a spray can. It was a little pricey, like $14 a can.
Old 02-07-2007, 08:12 AM
99_Z_155's Avatar
there is one i found that is close called Tahoe blue, dont remember the maker. but its not exact. what kind of detail painting you doing?
Old 02-07-2007, 09:48 AM
LS1Tech 10 Year
Just small parts, maybe my coils, a few other things.
Old 02-07-2007, 02:35 PM
zfastss's Avatar
I picked up a few spray cans a few years ago at Walmart of all places. It is Duplicolor GM505 if you can find it.
Old 02-07-2007, 04:11 PM
CAMAROZ28AQUINO's Avatar
Get one custom mixed from an autobody supply shop and get them to mix it into a spray can. I do this all the time and matches are perfect. Just give em the paint code.
Old 02-07-2007, 06:30 PM
No Juice's Avatar
LS1Tech 20 Year Member
Just go to your local GM dealer with your paint code. Small spray cans are $12
Old 02-07-2007, 10:10 PM
2002 Trans Am's Avatar
Same, here, not perfect, but very close IMO
Old 02-08-2007, 07:47 AM
PontiacFan's Avatar
GM dealer, I believe it's a 5oz spray can, 12371320.
Special order tho, so you'll have to wait for delivery.
Old 02-08-2007, 10:13 AM
KenrickCustom's Avatar
Can you get that stuff in a high temp also. I am thinking of getting my calipers painted NBM becuase I have a NBM bird. Do you tnink I even need hight emp. Will my calipers get that hot. Any ideas please
Old 02-08-2007, 09:28 PM
I don't remember if I used high temp color, but I did use high temp clear and it has held up good except for when chipped from changing wheels
Quick Reply: Is NBM available in a spray can anywhere?
