LS2 Manifold
LS2 Manifold
hey i was just wondering... wouldnt a LS2 manifold and TB bolt right up to my 408?? im looking for a cheaper upgrade than a FAST and that way ill also have the 90MM throttle body.
is it possible? they used the LS6 heads on the LS2's right? so id think it would work?
It would bolt right up to your heads, however you will also need to get the matching fuel rails. I would also suggest porting the intake, from reading some of the other threads about this subject. They were showing HP loss between the stock LS6 and then going to the stock LS2. After they ported the LS2 intake then they were finding their gains. You might also check into TPIS's LS6 int. converted to accept a large oval TB as a reasonable alternative for your project.
link plz? never heard of that
http://www.tpis.com/index.php?module...ake+Components
Now for that finders fee you promissed!
Sorry the links didn't post properly. You will have to just page over until you find the parts I was telling you about.
found em, good lord thats PRICY
