Pressure Plate Bolts?
Old 02-09-2007, 07:25 AM
1999ssls1's Avatar
Default Pressure Plate Bolts?
One of my flywheels bolt holes are stripped, so I tapped it for a bigger bolt. Is this fine? I still have 5 that havent been tampered with.
Old 02-09-2007, 03:38 PM
camaroguy26's Avatar
I'm not an expert this is just my opinion. but the only problem I see with it is you might get a vibration since it's not in balance anymore. I don't know if it'll be enough to cause a problem short term, it might wear out your clutches faster though.
Old 02-09-2007, 04:55 PM
gun5l1ng3r's Avatar
His "clutches" wouldn't wear out faster, but he might have a vibration and possibly wear out the Input Shaft Bearing and/or pilot bearing.
If it is your DD then you can probably get by with just throwing it back in, but if you have time to let it sit and work on it, I would get it balanced.
Old 02-09-2007, 05:39 PM
Ferocity02's Avatar
It you enlarged one, then enlarge them all to ensure proper balancing. Or if you're super lazy, the just enlarge the hole that's on the opposite side, this will also balance it out.
Old 02-09-2007, 08:41 PM
1999ssls1's Avatar
what would just leaving 1 out do?
Old 02-10-2007, 09:47 AM
1999ssls1's Avatar
anyone?
Old 02-10-2007, 11:58 AM
99ssleeper's Avatar
i wouldnt leave one out.
