Anyone REAL familiar w hptuner software
Anyone REAL familiar w hpt or other tuning software
I posted in pcm/diag and no one has answered and asked a few sponsors and not much info back. I am building a 96 v8 s-10 and using a 02 f-body pcm and harness. A fullsize truck uses a high resolution rear speed signal for the rear wheel speed input to the ABS. I need this for the abs on my 96' Since the pcms are the same does anyone know or can find out if the high resolution rear speed output can be turned on with hptuners or any other tuning software. The pin number for this output is c2 pin 49 yel/blk on the truck. Or can someone put in touch with someone who is knowledgable enough to help me. I was thinking about flashing it to the truck vin but I want to keep the a/c and fans controlled by the 3 wire pressure switch the f-bodies. mayday mayday mayday
