question about slp cold air intake?
I read that it is not recommended to put the slp cold air intake on the ws6 and SS camaro I have one at home and i already have the lid on it shoudl i not put the metal cold air intake piece in or should I?
you're a bit confused. most people say that if you add a cai kit to seal off the lid from the airbox with the little rubber seals they give you. that way, the airflow is more direct and should produce more hp than when combined with the air flow from the lid. some people dont do this so it's just a matter of personal preference. fyi, the slp cai is pretty crappy, both the ftra and ssra are better, but seeing as you already have the slp piece, go ahead and install it. it should be worth and extra 5 rwhp or so.
Seal off the air box w/ that rubber piece and install the cai. thats what i did and it works great here. I wish i knew why the slp 1 has gotten such a bad wrap. that is a good question. perhaps, because it is metal and not plastic. some ppl may think i heat soaks but thats not really the case.
i was just thinking that if its only the fact that it dose not reach all the way down that makes it crappy... id rather have the slp one because i already scrape my air damn guard and im stock height on stock rims.
I heard that ws6's should do it cause it opens that whole and defeats the purpose of our ram air or somthing, cause the only way it would work is if it had equal amounts of air pressure coming in from the bottum and through the raim air otherwise your loosing pressure at one of the two or somthing? does this sound correct?
Info
The SLP kit doesn't work as good because it does not direct air into the intake and it does not seal the airbox very well. They also use a glued on seal that is not removable for driving in the rain etc.
For the best performance with the FTRA, you HAVE to seal up the front of the airbox, regarless of what hood you have. You will get much higher pressure air from the bottom of the car than you will get through the hood which means the air will just bleed out through hood and decrease your performance gain.
