FS 2000 camaro forged and juiced All new
I have for sale my 2000 Camaro z28, it has been my car since at around 50,000 miles has seen a few diffrent setups and now i finally decided to get out of the game so my loss is your gain....
SS hood, SS wing, washed twice a week and waxed every two weeks, no door dings no scratches!!! Black roof, no ttops
!7" TT'S all fully polished no flaking discoloring etc. billet grill, clear corners
275-40-17 Kumho ecstas Asx bought in august plety of tread left, never burned out.. drilled front rotors, no pulsation present, gm durastop brake pads all around=no dust. rack and pinion replaced at around 85,000 miles, tie rods, new front hub.
interior is stock monsoon indash cd, all speakers factory with a newer amp, non are busted, has the nitrous switches in the center console near the ashtray hidden, purge button is the "o" in camaro near the foglight switch, all the steering controls work, fast window motors recently both replaced, 5% tint all the way around, machine cut and proffesionally done. incl. top visor on windshield, ice cold ac just recharged good heater...
now the engine!!! forged 346, dont have a list of every single thing for this engine since it was installed january 1st, 2007, off hand i know the rods are by eagle and the pistons by je,crank by eagle, mti y1 cam by comp cam, 287, 289, 238, 240, 605,609 on 112 Lsa, the engine also has heads ported by lloyd elliot, head job performed, new seals, new springs, mark shaner ported throttle body, ls1 airlid, k&N, Ported maf, Ls6 intake, !AIR !EGR, Hooker super comp headers, Custom Y pipe, Borla Adjustable cat back w/ intercooled tips, NX wet kit with bottle heater and gauge, and a purge
built 4l60e, also just this January 07, comes with vigilante 3800 stall still under warranty, heavy duty pump, billet servo, hardended sun shell, larger 1-2 shift band, hardened planets, all new fibers and steels, new input drum, rebuilt valve body, boosted line pressure, drilled spacer plate, overall brand new...shifts bad ***
Rear end is an upgraded Auburn unit with gm 3.73 gears, along with a girdle, mobil 1 synthetic fluid
the car as its sits right now has about 104,000 on the clock, the new setup is not tuned but runs well since its stil running on the old tuning from the previous setup, i work as a tech at a chevy dealership so its always been taken care of, tommorow i will get more specs on what all is in the engine exactly asking
15,000 or best offer, im wanting to go towards a new tahoe
open to offers let me know im in fort worth, this setup has less than 2,000 miles
call 817-690-8476 sergio anytime
Click here to watch forge-346-cam-ported-heads-notune
