Sts Boost Controller Reference
im running a line from brake booster to boost controller the question i have is what port on the controller do i connect to ?? it is a manual controller.
yes it its the sts boost controller, manual, i have it hooked up the way sts says to, but several people have suggested referencing the controller to the eng after the intercooler, thats the line im questioning , which line goes to the motor????
Wow thats worded wierd. The reference line at the brake booster is the best line to use. It is technically at manifold pressure, and where the boost builds up is at the Restriction. The Manual boost conrtroller should have an inlet side marked. I've ran two diff controllers. 1 had the inlet on the side, and outlet on the bottom, the other was the exact opposite!!! then the outlet should go to the side port on the Wastegate and the top port open to atmosphere
sorry it sounds messed up let me try again
i have the STS boost controller hooked up the way STS intended to the turbo and the wastegate,
i want to change the set up to reference boost off the brake boost line.
i will install a "T" in brake boost line and run a line back and connect to the ????
what line do i disconnect and connect back at the turbo area???
