325/60/15's and 10" prostars dont fit, help !!!
Old 02-21-2007, 10:04 PM
datsbad's Avatar
Default 325/60/15's and 10" prostars dont fit, help !!!
Ok , 15x10's and 7.5 bs ,Mickey T drag radials 325/60/15 , they hit the inside bad , what mods do I need to do ???? They wont even sit flush to the rotor mounting pad !!
I thought these would bolt right up ? I have a 9" rear but set up at stock length .
Old 02-21-2007, 10:23 PM
SiL3NtXWS6's Avatar
I am assuming you mean 325/50/15's. I responded in the other thread you hijacked and my post can be viewed here:
https://ls1tech.com/forums/showpost....4&postcount=10
Old 02-21-2007, 10:29 PM
datsbad's Avatar
yeah 50's , sorry to hijack .
what are you doing with that little torch in the pic?
Old 02-21-2007, 10:53 PM
SiL3NtXWS6's Avatar
In that picture, my friend is heating up the metal so we could bend it back a little more after we cut the bump stops off.
And yes, i run a small spacer, but i fit them on there without it. You need an adjustable panhard rod to center the tire.
Old 02-21-2007, 10:58 PM
datsbad's Avatar
thanks for the help.
Old 02-22-2007, 07:05 AM
gator's 99TA's Avatar
who in the world told you a 13" wide tire would fit without inner wheelwell modification? lol. lots of pounding and beating. or you can just cut out the bump stop area out with a torch.
Old 02-23-2007, 03:00 PM
Ping King's Avatar
youre gonna have to cut the bump stops out and do some smashings. Plus make sure the calipers are ground.
