Trying to put a 10 bolt non ASR in an ASR 2000 Camaro
Hey I was wondering if I took the axle and the backing plates would there be anyway to put in an non asr axle or maybe try just taken the asr off all together and putting on the current car that I have now with traction control. Any body got any Ideas I took the asr axle off a while back but had to cut the brake line holders that bolt to the axle. Please give any help that you can give, I'm new to this site so hopefully I put the post in the right place. I have an email address that I'm avalible at as well it is spookman2005@yahoo.com. If you want to send your respose there. Please let me know I just got back form Belgium with the army and they have seem to have tore up the axle again and have spent a lot of money to the point of brokeness trying to get my baby back running with a baby on the way and a job that I have to drive out to Arziona.
Thanks for any help,
Kevin
2000 CAMARO PEWTER
TR 224 224 114 CAM
Z06 RIMS
LED Under lights
TB PORT AND BYPASS
MAF SCREEN REMOVED AND POLISHED
(VINIC spelled wrong I think) TUNER
Help a broke man put his stuff back out on the street, Where it belongs.
Kevin
2000 CAMARO PEWTER
TR 224 224 114 CAM
Z06 RIMS
LED Under lights
TB PORT AND BYPASS
LS1Tech Sponsor
All you need to do is change the axles and backing plates unless the axle is out of an LT1 car. You might have to clearence the 4 bolt flange to clear the ABS sensor.
