P0128 dtc ?
Old 02-22-2007, 09:46 AM
silent1's Avatar
Default P0128 dtc ?
My engine started to buck and hesitate a lot on my way home yesterday, just running like garbage. After a while my ses light was finally triggered and a few seconds later, everything was ok. Hesitation and all were gone. The code is P0128 which is supposed to be "Coolant Thermostat (Coolant Temp Below Thermostat Regulating Temperature)" but when I looked at this same code in my LS1 Edit program it says "HO2S Bank 1 insufficient activity". Which one do I believe to diagnose my problem?
Old 02-22-2007, 11:28 AM
2001NBMZ28's Avatar
I'd start by looking at the ECT sensor. Is your car an '01? www.gearchatter.com/viewtopic9163.php
Old 02-22-2007, 12:37 PM
silent1's Avatar
Yeah, it's an '01. Why do you ask?
Old 02-22-2007, 01:10 PM
2001NBMZ28's Avatar
Just wanted to be sure I posted the right gearchatter link...
Old 02-24-2007, 09:29 PM
OUTLAWZ RACING's Avatar
If your coolent sensor is shitty or starts to go out the pcm would think its -20 degrees and it will dump an assload of fuel and it probably wipe out your o2
Old 05-29-2007, 09:59 AM
Eagle02's Avatar
Silent1-
What did you end up doing to fix this issue? My '02 WS6 just started doing this over the weekend...
-Eagle
Old 12-15-2008, 06:18 AM
DVS99TRANS's Avatar
Search saves my *** again
Quick Reply: P0128 dtc ?
