Cylinder Head Gurus-Can I use 317 heads drilled for 9/16 arp studs on stock LS6 block
Old 02-22-2007, 09:08 PM
Chicago Crew UnderBoss's Avatar
Default Cylinder Head Gurus-Can I use 317 heads drilled for 9/16 arp studs on stock LS6 block
Have a chance to pick up some 317 blower heads for my stock BLOWN LS6 motor, that have been massaged and drilled to accept 9/16 head arp head studs. I am going to be running up to 12 lbs of boost and what if anything can be done so these heads drilled 9/16 for arp head studs will work on my stock LS6 motor making up to 12 lbs of boost on my bone stock 346 LS6 motor.
THanks for your iput!
Old 02-23-2007, 09:11 AM
Somebody has to have the correct answer to this question?
Old 02-23-2007, 09:23 AM
Brian Tooley Racing's Avatar
If you are using stock fasteners then buy the head bolt bushings from TFS like they use on the Fords when using a head drilled to 17/32" (1/2" fastener) and using a 7/16" fastener. Here is the link to Summit http://store.summitracing.com/partde...9&autoview=sku
You do not need to use the ARP supplied washers when using these bushings.
Good luck!
Old 02-23-2007, 05:36 PM
Thanks Brian!
Old 02-23-2007, 08:21 PM
TheCarKid's Avatar
i've seen your car at the car shows in town. very nice car. Sounds awesome!
Old 02-25-2007, 10:52 PM
Thanks BRO and I am pretty certain I have seen your bad azz LS1 f-body there also. I hope the WEDS. night car shows go on this year as i have not heard anything and last year there was serious talk that it might be over with which would suck!
Old 02-26-2007, 01:06 AM
TheCarKid's Avatar
yea hopefully they'll let them go on this summer. otherwise we'll have to cruise somewhere else.
