15x10 with 275/50/15 drag radial fitiment
Old 02-23-2007, 11:43 AM
mushroom281's Avatar
Default 15x10 with 275/50/15 drag radial fitiment
ok well i have the 15x 8 prostar on there now but just ordered some 10's i will be using 275 50 15 mickeys will they just fit on on will i have to massage the inner fenders with the 275's
Old 02-23-2007, 02:03 PM
Old 02-23-2007, 02:04 PM
Javier97Z28's Avatar
With my car in the air and the axle hanging the 275/50/15's do not fit. They hit the jounce spacer area of the inner fender. I'm going to have to massage it most likely. I am not and will not be running spacers.
Old 02-23-2007, 02:46 PM
GM Muscle's Avatar
Yep with the car in the air they will hit the bump stop. But with my car on the ground they fit perfect, I didn't have to touch anything. My car is lowered 1.75". Either way, you shouldn't have to do much if anything.
Old 02-23-2007, 04:15 PM
eLTwerker's Avatar
275s shouldn't require bumpstop shaving. SS come with 275s stock. 26.1 tire diameter same as stock as well.
Old 02-23-2007, 04:36 PM
A 275/50/15 M/T DR is almost 1" wider than a 275/40/17 ZR tire.
Old 02-23-2007, 09:56 PM
eLTwerker's Avatar
Mickey Thompson's website suggests a 8.5" rim(+ or- 1") for the 275/50R15. Steve from SJM suggested this was lowballing it. Actually, more like 9.5"(+ or- 1") I would tend to believe him as he sells custom fitted Bogarts wheels for f body, and other, applications. He's been doing it for a long time. So, that gives a 275/50R15 a range of 8.5" to 10.5". 275/40R17 is listed as a 9"-11" rim width in the Wheel/Tire FAQ over at CZ28.com. Backspacing could take care of any fitment problems one would have with a 275/50R15 tire.
Old 02-24-2007, 07:48 AM
On a 10" wheel with 7.5" BS my 275/50/15's run the jounce spacer, and are 1" wider at the tread line than my 275/40/17's mounted on 17x9.5" wheels.
Old 02-24-2007, 07:58 AM
1bigcam's Avatar
what backspacing did you have on your 15*8
Old 02-25-2007, 10:31 AM
SIC LSX's Avatar
i have done 15x10 295/50's looked great!
Old 02-25-2007, 10:46 AM
LS69TA's Avatar
My 10" Prostars and a 6.5" bs with 275/50s fit perfect. I didn't ever have the car up in the air though, but I assume with the 1" less bs they MIGHT clear the bumpstop.
Old 02-27-2007, 11:48 AM
The Wingman
LilRick's Avatar
what about weld 15x10 with 7.5" backspacing and a 325/50/15 m/t et radial? I've seen lots of pics that look good but never heard if you have to use the BFH or not? Also goin with a 165/80/15 on the front? ANybody running these?
Old 02-27-2007, 02:30 PM
LS69TA's Avatar
The 165/80 is the popular size for the front. With the 325s usually there is some BFH'ing and possible fender rolling and bumpstop modifications.
Old 02-28-2007, 02:25 AM
skinnies's Avatar
Thats what I run, it does take a lot of modifications to make them fit though.
Old 02-28-2007, 08:53 AM
The Wingman
LilRick's Avatar
Now by "alot" you mean, cutting the bumpstop, "massaging" the inner fender and rolling the lip on the fender, right? I'm lookin at buying a fender lip roller. Do you have to be a body shop kinda guy to do this or can any experienced mechanic do this without buckeling the sheet metal?
Old 02-28-2007, 11:40 AM
Got Me SOM's Avatar
my buddy fit 15 x10 prostars with 7.5 backspacing with a 325/50/15 tire. he had to cut the bumpstop and whack the inside a little with a hammer.
you may have to get a panhard to center the rear.
no fender rolling necessary, he was at stock ride height.
Quick Reply: 15x10 with 275/50/15 drag radial fitiment
