18 X 10.5 ZO6 rear wheels. TIRE APPLICATION?
Old 02-26-2007, 10:25 AM
MeanHugger's Avatar
Default 18 X 10.5 ZO6 rear wheels. TIRE APPLICATION?
Hey everyone, I need some help. Looking though all these threads becomes rediculous after a while when i can just get some direct advice. I am running 18 X 10.5 ZO6 wheels on my 99 camaro. I am looking to throw some street radials on there. What im hoping will work is a set of 305 35 18. What i need to know is what is the biggest tire i can put on there without any banging of the wheel well. Or, should i get some spacers?
Old 02-26-2007, 11:32 AM
ls1muscle's Avatar
Just bang the wheel well, spacers will look stupid because your wheels will be sticking out. Once you've done that, then you can put on your 305 nittos.
Old 02-26-2007, 02:14 PM
ls1mightymouse's Avatar
Everytime i tried to use a spacer i couldnt get any of the lug nuts to fit and the spacers were thinner than snot! So i say no to any kind of spacer. You can beat the wheel well and still have it look nice if you cover it up with a little paint or something. I think 295 would be the widdest you could go without rubbing
Old 02-26-2007, 03:33 PM
Xsta Z 28's Avatar
When I ran 295/35ZR18 tires on C5 Z06 58 mm offset wheels I had to BFH . . . .
Old 02-26-2007, 04:34 PM
Turo's Avatar
I am running 295/35R18 on OEM Z06 rears and I did the BFH mod, but I don't think it was necessary, I did it more for the 'just in case' factor (my car is stock height for now).
Old 02-26-2007, 05:30 PM
RoastEmSS's Avatar
running factory 18x10.5 wheels of an 02 z06 with 315/30/18 BFG DRs, Did the BFG mod and still have a lil rubbing, but the BFG 315s are bigger than other 315s I hear, I'll be going with a 305 nitto DR next most likely
Old 02-27-2007, 10:31 AM
Hark_Z's Avatar
Im from St Charles too Hugger
