Bad Day at the dyno
Old 02-26-2007, 06:51 PM
dschmittie1's Avatar
Default Bad Day at the dyno
Well today I took the car to go get it tuned. the Day started out bad since we had to leave a little latter than planned do to some freezing rain and stuff the night before. But we made the 120mile trip to get my car tuned. Drove the car there. I had driven the car around saturday and it was great. The car was acting a little stupid on the way down to the tuners. But we got there and go situated put the car on the dyno and did a little driveability tunning and got ready to do some WOT tunning
So we got to make the first pull I put it in 4 gear and lay into the throttle and car start climbing and sounds great. Then at 5000rpm BANG. This noise was hellishly loud inside the car and everyone around the car jumped. My first thought was the bottum end or tranny due to the strange sounds as it was spining down. As it turns out the rear u-joint and the driveshaft are destroyed. Not sure which one went first but an ear is broken off the driveshaft.
But from that one pull I know that at 4800rpm with little to no tuning the car made 458rwhp and 502rwtq that was making 6# at that point. I have an 8# pulley on the car right now. I can't wait to see what kinda of numbers the car makes with a little more tuning and all 8psi at 6000+rpms
But the day ended with a nice long trip home with the car on a roll back. (Thank God for AAA+ with 100 miles of free towing) What a day
Old 02-26-2007, 07:15 PM
cablebandit's Avatar
sux but it coulkd have been worse and more expensive. AAA rocks...unfortunately i have used up my 4 free tows until July renewal
Old 02-26-2007, 07:21 PM
99Z28LS1's Avatar
yeah, it could been the bottom end or tranny like you said. i'd be happy with the problem you had instead of my bottom end going.
goodluck my friend, i wanna see more numbers soon
Old 02-26-2007, 07:42 PM
Speed's Avatar
That's kinda pimp in a sick way unless you forgot to put a retainer on
Old 02-26-2007, 07:52 PM
all of it was there and installed properly. Not sure exactly what failed eveything got all mangled up when from spinning around after it let go at 5k in 4th gear
Old 02-26-2007, 09:03 PM
quicksilverado's Avatar
Sucks about the driveshaft. AAA is the best.
Old 02-26-2007, 09:14 PM
RooRnZ28's Avatar
well at least she is partially tuned!! i drove my car around 200 miles to get her tuned, and i ended up leaving it there so they could fix the problems!! you'll be very happy when you go for the finishing tune!! good luck!!
Quick Reply: Bad Day at the dyno
