Sponsored by: DashLynx
Spyderwebd Paint!!!!!!!!!!
Old 02-27-2007, 05:40 PM
fastss's Avatar
Default Spyderwebd Paint!!!!!!!!!!
I have a couple of spots (one in the front of the car and the other in the back) where the paint is spyderwebd!!! maybe this is a stupid question but is this problem something i can get rid of by using Scratch/swirl remover? and if not will it atleast help it out to where its not so notisable? or is the only solution to repaint the car? THANKS alot felas!!!!
Old 02-27-2007, 06:07 PM
CAMAROZ28AQUINO's Avatar
nope, dont even try...i wouldnt even try wetsanding if its rate through the paint...get it blown in from a body shop!
Brian2006's Avatar
This can not be removed. It's fine cracks in the clear coat. Buffing will minimize it but eventually you'll burn through the clear and into the paint because of how deep spiderwebs usually are. Scratch-X will only fill it but it really won't change how it looks.
Old 02-27-2007, 09:55 PM
~JOSHUA's Avatar
You need to have the bumper cover repainted... if you want it fixed.
Old 02-27-2007, 09:58 PM
Ls1CamaroGuy87's Avatar
Even if you get it repainted the webs could show up again!
Old 02-27-2007, 10:10 PM
SSNISTR's Avatar
Why is that? If it's prepped right it shouldn't.
