U Joint part number cross-reference chart
I thought I would post this just in case someone wants to know a certain part number for a certain U joint. Included are Spicer, Neapco and Performance Dynamics (Neapco's high end joint) parts numbers for all different applications as well as conversion ujoints. For the stock fbody shaft, you need 3R (S44) joints. I would also recommend using a coated ujoint made for aluminum driveshafts to minimize the chance of galvanic corrosion between two dissimilar metals. Also, I was also told -not- to use Neapco's Brute Force line of ujoints, as they are not a very good joint and have inferior bearings. These Brute Force ujoints are found at a lot of discount auto parts stores and have a 'BF' at the end of the Neapco part number I believe.
Could we make this a sticky....??
UJOINT CROSS REFERENCE CHART
