Injector Pulse Time
Injector Pulse Time
I have changed from stock injectors to 83lb inj. what is a standard to set these at just to run car to start tuning it. 88mm turbo 60lbs fuel pressure at the rails to start. Just looking for something close as I am new to tuning. The car is being tuned with hpt stock pcm. Thanks.
Sticky: *READ ME FIRST-- Tuning Docs,VE/MAF, SES Lights, FAQS!!!! + more! *01/31/07*
Use the injector tuning .xls file to get an idea where you need to set your injector flow rate.
