So my car...
Old 03-01-2007, 07:24 PM
SlammedWS6Formula's Avatar
Question So my car...
..has been sitting for about 2 years. Ive drove it like 5 times, but thats it and not too far too. So, I want to make it my daily driver again. My question is what should I start fixing since its been sitting there a while?
-Oil
-Plugs
-Fuel filter
..what else?
Old 03-01-2007, 07:29 PM
Take 2's Avatar
Be Sure to Check the Tires........Has it Been Sitting with Gas in it.....May be Bad...Just some thoughts
Old 03-01-2007, 08:10 PM
yea with the tires on it. with a little gas in it, also, last time I moved it I had to pump new gas into it.
Old 03-02-2007, 08:49 AM
BlackHoleSunSS's Avatar
You should be ashamed of yourself.
Old 03-02-2007, 08:54 AM
TNormZ28's Avatar
valve guide seals...
01pewterbird's Avatar
ehh probably not a good call on only leaving alittle gas in it, should have kept it full with stabill. That gas is probably nasty now with a lot of moisture.
Old 03-02-2007, 10:11 AM
White 96LT1's Avatar
prime the oil before start up, check everything
Old 03-02-2007, 01:18 PM
Breakfast Fanatic
Pewter02TA's Avatar
Old 03-02-2007, 03:59 PM
I am, but Im making it better starting right now.
Old 03-02-2007, 04:01 PM
ckyconan2003's Avatar
well, se if it starts! If it does, get some gas in her and change the oil/oil filter!
Old 03-02-2007, 07:20 PM
Well, the battery is dead, got another and started it. Started up like a champ! Got some Mobil 1 10w30, oilfilter, some gas/fuelinjector treatment. I will change it tomorrow and fix the panhard rod problem.
Then I will try to tackle the other stuff, like a radiator flush, rearend oil change, clutch/brakefluid change, what else?
