flasing a4 tune to a m6
when you are going to flash the m6 pcm with the tune of an a4 do you copy paste everything or do you load a file from a stock a4 then make the changes?
you need to just transfer over the trans segment, trans diagnostic, and speedo segment, if you are using efilive.
If you are using another brand of software you have to just put in a new file that has the a4 in it. there are toooo many other things in the background of the bin to allow just a simple transfer of table vs table.
