what is your oil psi in your 98 fbody/vette?
Seeing that 98's have a bad rep. for oil pump failures, answer the following question:
If you have a stock oil pump in your 1998 fbody/vette, what oil pressure does it read at cold start, hot idle, at cruise, and under full load?
