Anyone replace JUST the 93-97 Slave cylinder?
Old 03-04-2007, 10:59 AM
mightyquickz28's Avatar
Default Anyone replace JUST the 93-97 Slave cylinder?
I was able to start my '96 383 Solid Roller last night. Elation turned to dismay after I tried to depress the clutch, felt resistance, pressed harder, then heard a snap. I got under the car to find that one ear of the two slave cylinder attachment points had snapped off. I stopped by Advance Auto Parts on the way home and they carry just the slave for around $4x.xx. That beats the socks off the full assembly I thought I "had" to buy from GM ($175?) last time. Anyway, after examining the slave cylinder that's still attached to the line in the car. it appears the line is captured by a very tiny pin. Have any of you replaced just the slave cylinder on a 93-97 T56 equipped Fbody car? THanks in advance...
btw-I did search before posting this. Most posts are about replacing the 98 - 02 LS1 version slave cylinders.
David K. Wilson
Last edited by mightyquickz28; 03-04-2007 at 11:00 AM. Reason: mistype of engine size
