Timing Dial??
Timing Dial??
A friend of mine was telling me about this box he got with a timing dial so that he could retard his timing for nitrous runs and then set it back to normal to make a NA run. Where can you get this for an LS1? Are they good to use? Worth it?
Sounds like it's a Timing Tuner. It's kind of like a MAF Translator, but for timing.
http://search.yahoo.com/search?p=LS1...p=mss&ei=UTF-8
LS1TECH Sponsor
alot of the GTP guys use these...basically its a switchable resistor for the IAT...you setup your IAT adder table the way you want it to pull timing & just switch it from one setting or another depending on how much boost or nitrous you plan on running. They are usually referred to as a Happy **** in that community.
