Northwest Members WA, OR, ID, MT, WY, SD, ND
Dyno results from TSP 2.5 LS6 Heads with 233/239 112+2
Old 03-05-2007, 10:06 PM
potac's Avatar
Default Dyno results from TSP 2.5 LS6 Heads with 233/239 112+2
Posted up in the dyno section
Old 03-05-2007, 11:20 PM
CHarris's Avatar
Thats a whole lotta cam. Looking at your dyno makes me understand what I feel in my car... I have heads and a 232/238 cam with ZO6 exhaust manifolds and the hp and torque come on very much like yours does on the graph. At 3500 mine really starts to pull
Old 03-05-2007, 11:35 PM
00Vette's Avatar
Nice numbers bro!!!
You planning on adding any nitrous?
Old 03-06-2007, 08:08 PM
potac's Avatar
Nitrous is always in the back of my mind. I almost pulled the trigger on getting a kit last year after talking to Robert at the track. I first need to take care of my sticking clutch.
Old 03-06-2007, 09:05 PM
00Vette's Avatar
ooooooooooh, that don't sound good! I hope you get that figured out.
But a nice little hit of nitrous will really throw you into some fast ET's. You'll spend a grand or so, to do it right and safe. But that is way way way cheaper than any other power adder.
Old 03-10-2007, 12:08 PM
tjwong's Avatar
Cory, he has more in it. When I tested the car on the final pull, the MAP sensor reading was at 95kpa @ WOT from about 5000 up to the test finish RPM. I advised him that he would definitely benefit from a 90mm intake and TB combination. I beleive there could be 15 to 20 at peak left in the engine if he were to get that intake revised.
