tailshaft seal
It is the seal that holds trans fluid from coming out the back of the trans. The drive shaft slides over the output shaf and through the seal. pull the drive shaft out and when it slides out the trans you will see the seal, looks like a big *** o-ring.
Originally Posted by Six Speeds Inc.
That is correct. The output shaft seal is on the back of the tailshaft housing and ours have a dust boot on it. The transmission yoke goes into the back where the tailshaft seal is. Hope this explination helped.
Thanks,
Amber
Thanks,
Amber
