Whats this noise??
Old 03-06-2007, 11:28 AM
97BBlackZ's Avatar
Default Whats this noise??
Recently i've had a noise coming from the shifter area. It only seems to have it when i'm in 6th gear and normally when i have my foot on the gas. It will go away if i let off it.
The sound isn't always there though. But i've been noticing it alot.
Its sort of a small vibrating sound. Kind of like 2 metal peices are vibrating on each other very light and fast.
Anyone know what it could be? Do i just need to add fluid? Also how do you add or check fluid in these things?!?
Old 03-06-2007, 12:36 PM
black01_WS6's Avatar
on the drivers side firewall you will see a small container that is holding some fulid, that is where you would add fluid. make sure you don't go over the line.
Old 03-06-2007, 07:25 PM
SpdFrk1990's Avatar
I think he is talking about the tranny fluid. There is a plug on the pass side to drain it if you want to add new and the fill plug is on the driver side.
Old 03-14-2007, 02:55 PM
CobraBob's Avatar
You never noticed the noise before? Have you worked on the shifter recently or replaced it recently?
Old 03-14-2007, 04:13 PM
meatfoam's Avatar
Yeah, do you have an aftermarket shifter?
The screws from the positive stop could make contact with the vibrating shifter stick.
