What's the difference?
Between the suspension on a 2002 WS6 T/A and a 1998 Z-28 camaro? I swapped the springs and shocks out on my Z-28 this past weekend along with the springs and shocks out of my buddies Trans Am. I couldn't tell a difference between the two. Our sway bars were the same, springs looked the same, shocks looked the same, etc.. So what exactly does a WS6 performance suspension consist of? I've always wondered this since I used to own a 1998 WS6 Vert before my T-top Z-28. His is a true WS6 too, has the Code in the door for proof along with the SLP sticker.
LS1TECH Sponsor
Front bar on a WS6 is 32mm vs. your 30 if they weren't different either someone put a 32 on your car, or took it off his. Springs are the same.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
I don't see how 2 mm could make that big of a difference in handling, the cars feel the same to me. Mine hasn't been changed, Devin bought his car used last year though so anything is possible.
LS1TECH Sponsor
23% stiffer because of that 2mm... Bar stiffness is a function of the OD to the 4th power.
__________________
