Mounting Oil pump for rear turbo need help?
I have a mocal oil pump to pump the oil back up to my oil cap, I was just curious of how I should go about mounting it. Should I use self tapping bolts? Or drill holes all way through and pull up carpet and use regular nut and bolt? Also I was thinking about cutting maybe 1cm of rubber hose and thread the bolt through so that the pump will not be directly touching the floor to keep vibration down.
