4 channel to 3 channel conversion
I have already searched and read the sticky!
I know it can be done, but has anyone here done it? I will just need the reluctor ring and the sensor correct? This is a 4 channel Moser 12 bolt going into a '02 3 channel car.
Thanks guys
Thanks guys
Originally Posted by 2002_Z28_Six_Speed
You would need to modify the ABS harness, get a 3 channel ABS module, the rear end, and some brake line work.
It is very do-able but most people don't want to do work that involving learning things or reading wiring schematics.
BlackScreaminMachine, thanks I figured I might have to, should be no problem.
THANK YOU!!! I don't know why I never found that thread during any of my searches. That info should apply to a 12 bolt rear as well correct?
