Morel link bar lifters LS1/2/6 picture
Super Hulk Smash
Originally Posted by motorbuilt
none on a hyd roller, it just adds weight and causes earlier valve train float etc
Plus a factory lifter holder has never failed, the link bar *could* fail..
Solid roller it would work great
For a hydraulic lifter, a tie-bar is just another moving piece that can fail and adds weight (not as significant over the camshaft for a hydraulic cam setup). The regular Morel lifters in LS2 lifter trays would be all you need.
I have never seen a lifter turn in the tray on a LS engine, but I guess it could happen. If you really have a fear of the lifter turning you can use a dog bone style retainer like the old GM or Ford engines. Jesel makes an all metal dog bone retainer for the LS engines, although you do need to mod the LS2 style blocks mildly to use it.
Kurt
Kurt
My lifter turned still stuck in the block and i cant pull it out. took my cam with it obviously. it was only one of the small things to go wrong in my cluster f_ck. I cant salvage anything that was worth saving(cam, heads, crank, block...) i dont know if the lifter turned during or after my motor gave out. the tray looks great too... plastic flexed enough to turn.
I think if the base circle of the cam is to small the lifter comes down to much and can turn.I know of two local cars this happen to with stock lifters.With the same cam also.
Originally Posted by Dragaholic
I'm going hydraulic, but an extreme hydraulic. Should I consider these or stick with the regular Morels or even something totally different?
Morel was asked by an LS1 cam core supplier to the industry to make link bar lifter because of failures they had seen from the lifter twisting in the bore on the more aggressive cam lobe profiles.
Weight has been brought up before, the Morel is more stable at high rpm then the Eaton/Delphi/Johnson or Stanadyne roller tappet. The trend to stablize valvetrain in larger diameter tappets and pushrods. With this comes added weight but on the cam side of the valvetrain it is not as important to be light as it is to be durable.
9 Second Club NA
I don't have any lifters as of yet. I was going to just get the regular Morels that have been around for a while, but then these came out. Wasn't sure if I should consider these since mine will be much more aggressive than most here. I'm looking at a max effort cam (unknown specs/builders will decide), 13.5:1 compression, 415-416 cu. in., etc. So the Caddy lifters probably aren't an option for me as they do support 8000+ rpms, but with light weight valvetrain. My valvetrain will be light, but it still gona have the huge intake valve which I'm not sure the Caddy lifter will support.
We have deleted the link bar in high output/durability gen 1 small and big blocks with great results. The reason we did this was mostly to stop link bar related failure. Reduced weight and reduced side load was just extra plus.
Our favorite hyd is still the Morel as it has proven durability in our testing at 7500+ rpm boosted drag engines and 7000 rpm na road race engines.
Kurt
Kurt
