Air removal Help needed asap
Where does the 1.38 freeze plug go when i take off the air tubes. And what other line do I have to plug there is one small one tube in the back that I am assuming I need to plug. Is there any thing else
The plug is for when you remove your EGR, and it goes in the opening left in the intake.
What year is your car? If it is a 1998, you don't need to plug anything when you pull out the AIR. IF it is newer, you plug the tube comiing from the back driver side of the intake. You will notice it when you are pulling the tubes out, that it will be the only thing left OPEN.
