Torque Arm Bolts
Torque Arm Bolts
I need the 2 long bolts that bolt the torque arm to the rear end of my 98 Trans Am. Does anybody know what size bolts these are. I'm hoping I can just pick these up at the hardware store.
no but if you replaced the stock tq arm then your going to need 4 bolts. I think the stock tq arm has 2 long ones those are available at the dealer ship. if you try and go to a bolt place they wont have the ones with the washer built on the hex bolt. Theyll give you a long *** bolt and a washer. which will eventually back out. When i broke my tq arm relocation mount on my moser i had this gear shop tap out the holes and put in some bolts from a 9" and welded that tq arm relocation mount to the moser. since i had already broken it twice.
