Speed Density Tuning w/LS1 Edit
Old 03-12-2007, 10:37 PM
DTSNGIT's Avatar
Default Speed Density Tuning w/LS1 Edit
Hey guys,
I don't have a wideband O2 sensor and want to get started SD tuning my F-body w/LS1 Edit and my Ease diagnostic software. Where's a good place to start? What all do I have to shut off or disconnect?
Mike
Old 03-12-2007, 10:40 PM
LS1TECH Sponsor
foff667's Avatar
what year & tranny?
before you go any further though, I would never recommend SD tuning to someone without a wideband...so it might be time to invest a couple bucks in one...JMO
Old 03-12-2007, 11:54 PM
racecar's Avatar
I was in the same situation several years back. There is only one good solution, buy a wideband, and HP Tuners.
Old 03-13-2007, 06:49 AM
DTSNGIT's Avatar
The car is a 2002 with the 4L60E auto trans. Thanks for the advice on the wideband.
Old 03-13-2007, 08:37 AM
LS1TECH Sponsor
foff667's Avatar
aight your in luck...many of the 98-00 operating systems when thrown into SD will command max line pressure...that you really won't have to worry about. In reality to enter speed density mode all you need to do is disconnect your maf sensor. If you want to enter Speed Density open loop youll also need to either disconnect one of your front o2 sensors or setup your open loop ECT table to a higher value then you'll ever actually see ie 284*F or something.
