M6 to TH350, do I have everything?
So here is the deal. I have done alot of searches(right now its down though) and have found parts and peices, but wanted to get everything straight and make sure I know everything I need to get.
Things I'm sure I need:
-RMVB TH350
-Conversion Crossmember
-Cable operated shifter
-Trans Cooler
-Converter
-Flexplate
-Tunnel mount torque arm
-sheet metal to cover shifter tunnel hole
-TH350 poly-mount
Things I am unsure of:
-Different size driveshaft?
-Trans oil hard or soft lines to cooler?
-Additional wiring?
-PCM modifications?
-Auto or manual console?
-pedal assembly?
...and anything else I missed.
Thanks for your help, James.
-RMVB TH350
-Trans Cooler
-Converter
-Flexplate
-TH350 poly-mount
-Additional wiring?
-PCM modifications?
-pedal assembly?
Originally Posted by Six Speeds Inc.
James,
You might want to try posting this in the automatic forum. Not many of the manual guys will respond to this. Hope this helps.
Thanks,
Amber
Thanks,
Amber
Thanks, I actually thought of that a few minutes ago and did just that.
