Ls6 intake............
Good looking intake. As stated, if the gaskets are in good condition, re-use them. Take them CAREFULLY out of your old intake. There is a small "dot" in the corner on the gasket. You can use a micro screwdriver or a scratch awl to start to get the gasket out. If you LS6 has them on it, I would just use the ones that will be coming off your current intake.
