QA1 and rear springs
Old 03-16-2007, 11:06 AM
weatherkid's Avatar
Default QA1 and rear springs
If im going to replace the rear springs what should i get to go with the qa1 kit im getting 300 lbs for the front, but just want to replace the rears and maybe lower an inch. its not a daily driver just for strip and weekend cruises downtown.
Old 03-16-2007, 12:59 PM
98_LS1's Avatar
I'm in the same situation. I already have a set of strano springs so i'm just gonna use the back springs to lower the rear of the car and use the adjustable coil overs to lower the front.
BMR sells just the rear springs and they advertise a drop of 1".
Old 03-16-2007, 05:21 PM
you2slo's Avatar
The hose mod may do it for you. QA1's and 300# springs up front and stock stuff in the back with the hose mod. Will upgrade to QA1's in the rear sometime.
Old 03-16-2007, 10:08 PM
Ping King's Avatar
i run 300s up front and the hose mod in the back. Best set up
