crank position sensor??? please help.
I am not sue if this is the right forum for this question. If not I apologize. I think I am having a problem with my crank position sensor, So my question is, Is there any way for me to check and see if my sensor is good or not? Thank you in advance for any posts that can help.
If you have the code look it up at www.gearchatter.com If it's bad and you replace it believe you need to do a relearn.
I kept throwing a crank sensor code it kept coming back.....Turned out that these two wires on the passenger side were rubbing against the header, causing that code to throw its self.
Good Luck with the repairs.
