Centerforce Clutch
Old 03-18-2007, 01:01 PM
Fordstanggt01's Avatar
Default Centerforce Clutch
Hey whats up.....I'm Looking to get a centerforce for my 01 Mustang GT convert. and when ordering it says 10-spline 11-in. Diameter Disc as one option then 26-spline 11-in. Diameter Disc as another for only a couple extra bucks, whats the diffrence and how do i know which one to buy, thanks
Fordstanggt01 is offline
Old 03-18-2007, 01:07 PM
styoung's Avatar
most newer trannys have a corse spline input shaft, 26 spline and olders have the 10 spline input shaft. you most likely have the 26 spline input shaft.
dont guote me on that i dont know much about stangs/fords.
styoung is offline
Old 03-18-2007, 01:09 PM
hey any info helps, thanks
Old 03-18-2007, 02:58 PM
myfast70's Avatar
You may want to move this to the manual trans forum, you will probably get more help there. BTW, you want advice, STAY AWAY FROM CENTERFORCE, THEY ARE GARBAGE!!
myfast70 is offline
Old 03-18-2007, 03:11 PM
what should i get then
Old 03-19-2007, 09:45 AM
chris01ws6's Avatar
My buddy just pulled a centerforce out of his z28 and all the pucks just fell off. I hear spec clutches are good. good luck man
chris01ws6 is offline
Old 03-19-2007, 10:37 AM
WILWAXU's Avatar
Might try our mustang site:
http://www.modmotortech.com/forums/
WILWAXU is offline
