cam on budget
cam on budget
I want to install my LE1 cam this spring but I need to run on a very tight budget (replacing clutch, roadtrips, ect.)... What do I absolutely need and what can I keep and use again?
This will be installed by myself.
By the way, the timing chain was replaced with the opti less than 2000 miles ago
I would get new lifters and springs to be on the safe side. IMO you should be good after that. I know some people that have put new cams in and left the stock lifters in and the car ran good. I am not sure about the push rods.
There are others that Know more than me that could help. so good luck on your car.
