lt1 + nitrous = what timing
i got a bolt on car and gonna run nitrous this season before i do any motor work. I was planing on working my way up to a 200 shot. I got a 6al box, dig. window switch and a adj. timing box with the turn **** to adj. timing. My question is how much are you guys runing on stock timing? Iv seen one guy runing a 150 shot on stock timing. If thats the case i might just sell my adj. timing box and run a 150 shot and call it a day. How big do you got on stock timing?
I have sprayed 150 before on stock timing, but its only because I forgot retard the timing. I have the same adjustable timing setup. I would take out 3-4 deg for a 150 shot. Anything over that I would step up to 100+ octane fuel, and pull 4-5 degrees. Also if your using a fogger nozel, anything over 150 I would recomend multiple nozels. Jet both of them for 100, or both for 90, ect, depending how much you wanna spray the car.
