Looking for some part numbers, can't find online
Old 03-25-2007, 08:49 PM
Mike94ZLT1's Avatar
Default Looking for some part numbers, can't find online
I'm getting the part numbers together for all the gaskets and crap I need for my new engine. So far I have everything but the following:
-Rear cover gasket
-Rear crank seal
-Valley cover gasket
-Cover thingy on the side of the oil pan above the filter
Are oil pan gaskets the same for C5's as they are for F-bodies? I think I have an old (but still unopened) oil pan gasket I bought for my 99 SS a few years ago from when I did rod bolts, somehow I ended up with an extra one...
thanks guys!
Old 03-25-2007, 09:28 PM
brad8266's Avatar
They are all here http://www.thunderracing.com/catalog...vid=3&pcid=227
What the hell is the cover thingy you are asking about on the side of the oil pan? I think you are talking about the part of the oil pan gasket that is in that area.
Old 03-26-2007, 12:20 AM
Mike94ZLT1's Avatar
Thanks for the link! On F-bodies it is a cover held on by 2 10mm bolts, but on a Corvette the oil temp sensor goes there. It's on the drivers side of the block above where the oil filter goes, and it is definitely a separate gasket.
Old 03-26-2007, 12:36 AM
Mike94ZLT1's Avatar
Now I'm confused.... Look at this pn# on GMPartsdirect.com
GM PART # 12499228
CATEGORY: Engine Front Cover Gasket
PACK QTY: 1
GM LIST: $53.00
OUR PRICE: $38.58
DESCRIPTION: GASKET KIT
LS engine camshaft installation kit
LS eninge cam installation kit includes front engine cover gasket, water pump gasket, intake manifold gaskets, valve cover gaskets, balancer bolt, and front seal.
Then, look at this part number:
GM PART # 12533587
CATEGORY: Manifold Gasket
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $79.32
OUR PRICE: $47.02
Old 03-26-2007, 06:33 AM
brad8266's Avatar
GM PART # 12499228
PACK QTY: 1
GM LIST: $53.00
OUR PRICE: $38.58
GM PART # 12533587
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $79.32
OUR PRICE: $47.02
You arent getting that entire gasket set for only $38, that must be a mistake.
I would order all that **** from thunder, they have fast shipping and they havent jacked up an order i made yet.
Old 03-26-2007, 11:43 AM
Mike94ZLT1's Avatar
I'm not ordering it from GMPD, I just wanted to use it to check part numbers and prices on things. I thought there was something funny with the price on that...
Same thing here...
http://www.trademotion.com/partlocat...&siteid=214638
The gasket kit is cheaper than the gasket by itself!
