Tr230/224 Reverse Split
Old 03-26-2007, 04:53 PM
KONG's Avatar
Default Tr230/224 Reverse Split
Just curious about the cam. Has anyone run this cam before? What kind of numbers do you normally see with this cam? How is drivability? Are there better reverse split grinds floating around out there? Looking for good power under the curve, not a dyno queen. Any help will be appreciated, thanks guys!!
Old 03-26-2007, 04:59 PM
LS1 Tech Administrator
Patrick G's Avatar
This cam has been around since 2001. It is a proven cam in making strong power under the curve. There are literally YEARS of results. FWIW, I ran the first one in my '98 SS Camaro Convertible. Ran awesome! Still a powerful cam because of the solid valve events.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 03-26-2007, 05:22 PM
steveo346's Avatar
Well I Made 390/380 To The Wheels On A Cam Only 99 Ss With 76k On The Motor And A 12.20 With A 1.7 60ft I Know With Some Suspension Mods And A Trans Rebuild It Would Run A Good High 11 For Shizzle
I Highly Recommend This Cam....has Awesome Street Manners And Sounds Rowdy As Fawk!!!
KONG's Avatar
Thanks for the input Patrick. Just looking for a good cam that has good dcr or can produce good dcr. I'm working with stock 243's, an ls6 intake, and full exhaust. Just want a cam that works well with stock or a little better compression.
Old 03-26-2007, 05:26 PM
Studytime's Avatar
Mill those 243s .020" and you'll have great DCR with a TR230/224. Also, don't forget to search, please. There's a lot (whole lot) of info out on this cam.
Ben T.
KONG's Avatar
Yeah man, I tried to play your idle video today but it wouldn't load up at work. I have read and heard nothing but good things about this cam and I am seriously considering it. Do you have to use dual valvesprings with this cam??
Old 03-26-2007, 05:31 PM
KONG's Avatar
Ben T.
Roger that bro. I will do more research on this cam. I personally haven't heard alot about reverse split style cams. Sorry if I just added to an assload of threads already out there about this cam
Old 03-26-2007, 05:41 PM
Studytime's Avatar
No problem. I don't think you could go wrong with the grind at all. It's been said several times that there has never been one person ever post negatively about this camshaft.
Ben T.
Old 03-26-2007, 07:09 PM
Super Moderator
Reckless's Avatar
I think you would like it a lot, but I am biased
Old 03-26-2007, 07:20 PM
KONG's Avatar
I think I would like it alot too. I read in another thread that the 224 exhaust duration is for cars with less than optimal exhaust, is that true? My car has full exhaust, lt's, ory, cat-back. Just wondering whether or not more duration on the exhaust side is needed? Or am I getting greedy? My car will have stock 243's, just dont want to go overboard in the cam department.
Old 03-26-2007, 07:28 PM
phoenix1987's Avatar
Cam is sweet! Curently running open headers in a third gen. Has a nasty lope. Would def buy again!
Old 03-26-2007, 08:34 PM
LS1TECH Sponsor
badpewter-z's Avatar
i loved that cam , drove great on the street very responsive down low. i made 380/370 threw a 9" with basic bolt-ons too.
and sounded mean too lol
Old 03-26-2007, 08:39 PM
PREDATOR-Z's Avatar
Actualy it is the opposite. It is for car with less than optimal intake.
Great cam for stock heads and likes high compression too. I wouldn't mill but I would go with .040 gasket, that would be similar to running 61cc chambers, bumping your SCR/DCR in a performing zone.
Old 03-26-2007, 08:48 PM
lastcall190's Avatar
I had a thread where I had hypothesized doing exactly what Predator said, .040 gasket, unmilled, and had a DCR in the 11.1x:1 range (or is it SCR? I mix 'em up...). I think I am actually gonna go back to looking at this route... I've seen too many good reviews and NEVER a bad one.
-J
Old 03-27-2007, 05:50 AM
KONG's Avatar
Thanks for the info man. I think I will apply that advice.
Old 03-27-2007, 08:36 PM
2fast97Z's Avatar
dyno numbers in sig..great cam except for my floating idle problem
Old 04-03-2007, 07:27 PM
gillbot's Avatar
My dyno graph is here: https://ls1tech.com/forums/dynamometer-results-comparisons/476349-tr230-224-a4-dyno.html
399RWHP through a PT4000 race converter.
