Can't tune
Old 03-28-2007, 03:41 PM
exit's Avatar
Default Can't tune
I've tried to tune but i don't think there is any power getting to the OBD-II port.... my cig lighters arn't getting any power eigther....
I already checked the fuse and its okay... so im stuck..
Old 03-28-2007, 03:51 PM
2001NBMZ28's Avatar
You sure the "CIG/ACCY" fuse is ok? Do a continuity check on the fuse spades/replace it anyway. If it's good probe the DLC terminals with a meter to check for power.
Old 03-28-2007, 05:02 PM
exit's Avatar
I guess i can replace the fuse anyway but i dont think it'll make a differnce...
if the cig's were disconnected would this affect the DLC terminal?
Old 03-28-2007, 05:07 PM
TAQuickness's Avatar
yup. if the cigaret lighter fuse is blown, the obd2 port will be unpowered as well.
Old 03-28-2007, 08:32 PM
exit's Avatar
OK i figured out what it is....
the DLC terminal is in fact getting power (checked it with a volt meter).... but there is some corrosion on the 16th little tooth... so im gona have to pull it off and put a new tooth cuz it's just not making any contact....
thanks for the help though!
once thats fixed... i can start learning how to tune
