Got HP tuners
Got HP tuners
So I played around with it a little tonight. About the only thing usefull that I got accomplished was changing the speedo for my tire size (285/35/18 vs 275/40/18 )
I also played around with the scanning tool feature. Kinda fun. I did notice that I can turn the "1 to 4" shift light on in the scanner. Then I noticed that there is some parameters to enable it in the programming mode, so I'm going to see if I can get it to work as a shift light.
There are a few other things that I want to do with it that I'm not sure it will do, and will require more research.
I assume you can install it on 2 computers
and my buddy has an 05 GTO, so it doesn't have to be the same car. Its just that were not buying the "all cars year/model" liscence. We're getting the individual car liscenses.
Originally Posted by jewbacca
Maybe thats what I need to do this summer. Now just gotta find someone with a 99 Camaro who wants it too. Can you install it on 2 different computers?
Program more than likely can be installed accross more than one computer to make changes to files, but you can't write to the PCM in the car w/o the hardware to plug into the PCM port under the steering wheel.
Tuners imo are amazing things, and overlooked by many. When doing simple bolt-ons they aren't totally necessary but when doing a cam I am sure it can help. With my GTP useing my tuner on that it more than likely saved my engine, it alerted me to the 14* of KR I was getting going WOT and I realized... platinum plugs aren't good for FI engines.
