tire rotation and psi question
i have a 97 z28..running 245 35 zr19's...ive had them for about 3k miles now..i was wondering when should i rotate them (miles wise)?and if i should get an allignment right away and/or get them balanced again... and also what psi should i run them...thanks guys
I thought I read something about NOT rotating your tires...something with balancing and wear ride handling......Look at it this way,,your going to buy 4 new ones when you need them. I always tried to rotate them to even the tread wear and well it never really worked ,,besides flats are always messing things up cause you'll always be looking to put that one bad tires on the backside some where. I just ride on them till i think I need some rubber and buy 4 more.
Originally Posted by HIZPANICGUY21
Thats A Good Idea..anyone Can Remember That..thanks..now What Psi Should I Run My Tires At?anyone?
